本文实例为大家分享了C#仿微信红包功能的具体代码,供大家参考,具体内容如下
Program.cs代码:class Program{static void Main(string[] args){//初始化要发起的红包基础数据double total = 100;int num = 50;double min = 0.01;string temp;bool flag = false;Console.WriteLine(string.Format("是否需要自定义红包金额和数量(默认{0}元/小贝人)Y/N:", total, num));temp = Console.ReadLine();if (temp.Trim().ToLower().Equals("y") || temp.Trim().ToLower().Equals("yes")){Console.WriteLine("请输入你要发起的红包金额:");do{temp = Console.ReadLine();flag = double.TryParse(temp, out total);if (!flag){Console.WriteLine("金额必须为整数或小数,请重新输入:");}} while (!flag);Console.WriteLine("请输入你要发起的红包个数:");do{temp = Console.ReadLine();flag = int.TryParse(temp, out num);if (!flag){Console.WriteLine("红包个数必须为整数,请重新输入:");}} while (!flag);}total -= min * num;if (total < 0){Console.WriteLine("抱歉,你的金额不足!");return;}//产生正态分布的随机红包金额,并计算相关的金额和数量保证数据的准确性double average = total / num;double variance = 1;Random u1 = new Random();Random u2 = new Random();double[] nums = new double[num];for (int i = 0; i < num; i++){double? result = total;if (i < num - 1 && total > 0){do{result = Round((double)Normal(u1.NextDouble(), u2.NextDouble(), average, variance), 2);} while (result == null || result < 0);if (total > result){total = (double)Round((total - (double)result), 2);}else{result = total;total = 0;}}else if (i == num - 1){total = 0;}nums[i] = Math.Round(min + (double)result, 2); //浮点运算问题,这里需要四舍五入数据才正确Console.WriteLine(string.Format("第{0}个红包金额:小贝", i + 1, (min + result)));Console.WriteLine("剩余金额:" + ((i != num - 1 && total == 0) ? min * (num - i - 1) : total + (min * (num - i - 1))));}Console.WriteLine("最大金额:" + nums.Max());Console.WriteLine("最小金额:" + nums.Min());Console.WriteLine("总额:" + Round(nums.Sum(), 2));Console.WriteLine("初始方差:" + variance);Console.WriteLine("结果方差:" + Variance(nums));Console.WriteLine("按任意键退出!");Console.ReadKey();}////// 产生符合正态分布的随机数//////正态分布第一个随机数///正态分布第二个随机数///正态期望(平均值)///正态标准差(Math.Sqrt(方差))///public static double? Normal(double u1, double u2, double averageValue, double variance){double? result = null;try{result = averageValue + Math.Sqrt(variance) * Math.Sqrt((-2) * Math.Log(u1)) * Math.Sin(2 * Math.PI * u2);}catch (Exception){result = null;}return result;}////// 求一组数据的方差//////要求的数组///public static double Variance(double[] nums){double average = nums.Sum() / nums.Length;double sum = 0;double variance = 0;foreach (double num in nums){sum += Math.Pow((num - average), 2);}variance = sum / nums.Length;return variance;}////// 截取小数指定小数位,且不四舍五入//////要截取的小数///截取小数后位数///public static double? Round(double originNum, int lastNum){double? result = null;int index = originNum.ToString().IndexOf('.');if (index != -1){string temp = originNum.ToString();result = Convert.ToDouble(temp.Substring(0, index + 1) + temp.Substring(index + 1, Math.Min(temp.Length - index - 1, lastNum)));}if (result == 0){result = null;}else if (index == -1){result = originNum;}return result;}}复制代码
