本文实例为大家分享了Android九宫格图片展示的具体代码,供大家参考,具体内容如下
复制代码
- using System;
- using Microsoft.CSharp;
- using System.CodeDom.Compiler;
- class Program
- public static void Main()
- // The C# code to execute
- string code = "using System; " +
- "using System.IO; " +
- "public class MyClass{ " +
- " public static void PrintConsole(string message){ " +
- " Console.WriteLine(message); " +
- // Compiler and CompilerParameters
- CSharpCodeProvider codeProvider = new CSharpCodeProvider();
- CompilerParameters compParameters = new CompilerParameters();
- // Compile the code
- CompilerResults res = codeProvider.CompileAssemblyFromSource(compParameters, code);
- // Create a new instance of the class 'MyClass' // 有命名空间的,需要命名空间.类名
- object myClass = res.CompiledAssembly.CreateInstance("MyClass");
- // Call the method 'PrintConsole' with the parameter 'Hello World'
- // "Hello World" will be written in console
- myClass.GetType().GetMethod("PrintConsole").Invoke(myClass, new object[] {"Hello World" });
- Console.Read();
