本文实例讲述了C#微信接口之推送模板消息功能。分享给大家供大家参考,具体如下:
复制代码
- public string SendTempletMessge()
- string strReturn = string.Empty;
- try
- #region 获取access_token
- string apiurl = "https://api.weixin.qq.com/cgi-bin/token?grant_type=client_credential&appid=你的appid&secret=你的secret";
- WebRequest request = WebRequest.Create(@apiurl);
- request.Method = "POST";
- WebResponse response = request.GetResponse();
- Stream stream = response.GetResponseStream();
- Encoding encode = Encoding.UTF8;
- StreamReader reader = new StreamReader(stream, encode);
- string detail = reader.ReadToEnd();
- var jd = JsonConvert.DeserializeObject(detail);
- string token = (String)jd.access_token;
- #endregion
- #region 组装信息推送,并返回结果(其它模版消息于此类似)
- string url = "https://api.weixin.qq.com/cgi-bin/message/template/send?access_token=" + token;
- string temp = "{\"touser\": \"" + UserInfo.OpenID + "\"," +
- "\"template_id\": \"f3kRRjJeyLDf4tndtg-OJeRvgEdgjjDxCy4T9kuwM70\", " +
- "\"topcolor\": \"#FF0000\", " +
- "\"data\": " +
- "{\"first\": {\"value\": \"您好,您有一条回款通知信息\"}," +
- "\"keyword1\": { \"value\": \"单位名称\"}," +
- "\"keyword2\": { \"value\": \"日期\"}," +
- "\"keyword3\": { \"value\": \"金额\"}," +
- "\"keyword4\": { \"value\": \"业务员\"}," +
- "\"remark\": {\"value\": \"\" }}}";
- #endregion
- //核心代码
- GetResponseData(temp, @url);
- strReturn = "推送成功";
- catch (Exception ex)
- strReturn = ex.Message;
- return strReturn;
- /// 返回JSon数据
- ///要处理的JSON数据
- ///要提交的URL
- ///返回的JSON处理字符串
- public string GetResponseData(string JSONData, string Url)
- byte[] bytes = Encoding.UTF8.GetBytes(JSONData);
- HttpWebRequest request = (HttpWebRequest)WebRequest.Create(Url);
- request.ContentLength = bytes.Length;
- request.ContentType = "json";
- Stream reqstream = request.GetRequestStream();
- reqstream.Write(bytes, 0, bytes.Length);
- //声明一个HttpWebRequest请求
- request.Timeout = 90000;
- //设置连接超时时间
- request.Headers.Set("Pragma", "no-cache");
- HttpWebResponse response = (HttpWebResponse)request.GetResponse();
- Stream streamReceive = response.GetResponseStream();
- Encoding encoding = Encoding.UTF8;
- StreamReader streamReader = new StreamReader(streamReceive, encoding);
- string strResult = streamReader.ReadToEnd();
- streamReceive.Dispose();
- streamReader.Dispose();
- return strResult;
涉及到的实体:
复制代码
- public class WXApi
- public string access_token { set; get; }
