摘要:在JavaScript世界中,有些操作会让你无法理解,但是却无比优雅,如果你真正了解这些,BAT公司任你选。一、5种方式实现值交换1. var temp = a; a = b; b = temp; (传统,但需要借助临时变量)2. a ^= b; b ^= a; a ^= b; (需要两个整数)3. b = [a, a = b][0] (借助数组)4. [a, b] = [b, a]; (ES6,解构赋值)5. a = a + b; b = a - b; a = a - b; (小学奥赛题)复制代码二、去掉小数部分parseInt(num)~~numnum >> 0num | 0复制代码三、判断 x 是否是整数function isInt(x) {return (x ^ 0) === x}// return Math.round(x) === x// return (typeof x === 'number') && (x % 1 === 0)// ES6 -> Number.isInteger()复制代码四、递归求阶乘function factorial(n) {return (n > 1) ? n * f(n - 1) : n}复制代码五、判断符号是否相同function sameSign(a, b) {return (a ^ b) >= 0}复制代码六、克隆数组arr.slice(0)复制代码七、数组去重// ES6Array.from(new Set(arr))// ES5arr.filter(function(ele, index, array){return index===array.indexOf(ele)})复制代码八、数组最大值function maxArr(arr) {return Math.max.apply(null, arr)}复制代码九、数组最小值function minArr(arr) {return Math.min.apply(null, arr)}复制代码十、随机获取数组的一个成员function randomOne(arr) {return arr[Math.floor(Math.random() * arr.length)]}复制代码十一、产生随机颜色function getRandomColor() {return `#${Math.random().toString(16).substr(2, 6)}`}复制代码十二、随机生成指定长度的字符串function randomStr(n) {let standard = 'abcdefghijklmnopqrstuvwxyz9876543210'let len = standard.lengthlet result = ''for (let i = 0; i < n; i++) {result += standard.charAt(Math.floor(Math.random() * len))}return result}复制代码十三、深拷贝JSON.parse(JSON.stringify(obj))复制代码十四、打印出来看看console.log(([][[]] + [])[+!![]] + ([] + {})[!+[] + !![]])console.log((!(~+[]) + {})[--[~+''][+[]] * [~+[]] + ~~!+[]] + ({} + [])[[~!+[]] * ~+[]])复制代码十五、美化consoleconsole.info("%c哈哈", "color: #3190e8; : 30px; : sans-serif");复制代码
