本文主要是通过一个银行用户取钱的实例,演示java编程多线程并发处理场景,具体如下。
从一个例子入手:实现一个银行账户取钱场景的实例代码。
第一个类:Account.java
账户类:
复制代码
- package cn.edu.byr.test;
- public class Account {
- private String accountNo;
- private double balance;
- public Account(){
- public Account(String accountNo,double balance){
- this.accountNo = accountNo;
- this.balance = balance;
- public int hashcode(){
- return accountNo.hashCode();
- public String getAccountNo(){
- return this.accountNo;
- public double getBalance(){
- return this.balance;
- public void setBalance(double balance){
- public Boolean equals(Object obj){
- if(this == obj)
- return true;
- if(obj != null && obj.getClass() == Account.class){
- Account target = (Account)obj;
- return target.getAccountNo().equals(accountNo);
- return false;
第二个类:DrawThread.java
取钱线程类:
复制代码
- public class DrawThread extends Thread {
- private Account account;
- private double drawAmount;
- public DrawThread(String name,Account account,double drawAmount){
- super(name);
- this.account = account;
- this.drawAmount = drawAmount;
- public void run(){
- // synchronized (account) {
- if(account.getBalance() > drawAmount){
- System.out.println(getName() + "取钱成功,吐出钞票:" + drawAmount);
- // try{
- // Thread.sleep(1);
- // catch(InterruptedException e){
- // e.printStackTrace();
- account.setBalance(account.getBalance() - drawAmount);
- System.out.println("\t 余额为 : " + account.getBalance());
- } else
- System.out.println(getName() + "取钱失败,余额不足!");
- public static void main(String[] args){
- Account acct = new Account("123456",1000);
- new DrawThread("A",acct,800).start();
- new DrawThread("B",acct,800).start();
上面代码中注释掉的部分:(1)synchronized同步代码块 (2)线程休眠。如果注释掉(1)、(2),则运行结果有多种可能性,可能性之一(概率较小),符合正常逻辑:
B取钱成功,吐出钞票:800.0
余额为 : 200.0
A取钱失败,余额不足!应该是B先强找到取钱资源,并且正确修改余额后,A才开始判断用户余额;这种概率非常小,多数运行会类似以下情况:
A取钱成功,吐出钞票:800.0
B取钱成功,吐出钞票:800.0
余额为 : -600.0
余额为 : 200.0这明显是不符合逻辑的,从运行结果可以猜测,A先抢占资源,取出金额,但在修改余额之前,资源被B抢占;由于余额未被修改,则B看到余额仍然是800,B仍然取出金额;A先运行修改余额,但并未打印,B抢夺资源;B修改余额,并打印余额,为-600;A打印余额,为200;
如果加上(2)线程休眠,则一定是错误状况,因为A或B在取出金额后一定会因为sleep释放CPU资源,JVM会调用其他处于准备状态的进程。第二个取钱判断余额一定是错误的。
如果加上(1)synchronized同步代码块,在线程run方法体中对account进行加锁;则每次都会保证执行逻辑正常:
A取钱成功,吐出钞票:800.0
余额为 : 200.0
B取钱失败,余额不足!
可以设想一下执行过程:A先抢占资源,在run方法体初始对account类进行加锁;然后开始执行同步代码块;如果执行到中间某个环节,CPU资源被B抢占;B开始执行,一开始也会对account类进行加锁。但是加锁时会发现account已经被A占用,则会调整为阻塞状态等待A释放资源;A执行完同步代码块后释放account的锁,B继续执行;B运行时看到的余额保证是A已经修改过的,会按照正确逻辑正常执行。
