解析excel文件
//fileName为文件的名称,path为文件的路径,nameRow为excel中列的名称的起始行数,valueRow为值的起始行数,excel行数是从0开始的
public static ArrayList<Map<String, Object>> readExcelrowKuaiBao(String fileName, String path, int nameRow, int valueRow) throws IOException {
ArrayList<Map<String, Object>> Row = new ArrayList<Map<String, Object>>();
try {
Workbook workBook = null;
try {
System.out.println(path + "/" + fileName);
workBook = new XSSFWorkbook(path + "/" + fileName);
} catch (Exception ex) {
workBook = new HSSFWorkbook(new FileInputStream(path + "/" + fileName));
for (int numSheet = 0; numSheet < workBook.getNumberOfSheets(); numSheet++) {
Sheet sheet = workBook.getSheetAt(numSheet);
if (sheet == null) {
continue;
Row row0 = sheet.getRow(nameRow);
if (null == row0) {
continue;
int colum = row0.getPhysicalNumberOfCells();
List<String> keys = new ArrayList<String>();
for (int i = 0; i < colum; i++) {
Cell cell = row0.getCell(i);
keys.add("column" + i);
// 循环行Row
for (int rowNum = valueRow; rowNum <= sheet.getPhysicalNumberOfRows(); rowNum++) {
//是否到达文件末尾
boolean isEnd = true;
Row row = sheet.getRow(rowNum);
if (row == null) {
continue;
// 循环列Cell
Map<String, Object> arrCell = new HashMap<String, Object>();
for (int cellNum = 0; cellNum < colum; cellNum++) {
Cell cell = row.getCell(cellNum);
if (cell == null) {
arrCell.put(keys.get(cellNum), " ");
} else {
//System.out.println(getValue(cell));
arrCell.put(keys.get(cellNum), getValue(cell));
for (Object obj : keys) {//遍历key
isEnd = arrCell.get(obj) != null && !"".equals(arrCell.get(obj).toString()) ? false : true;
if (!isEnd)
break;
if (isEnd) {
break;
Row.add(arrCell);
} catch (IOException e) {
System.out.println("e:" + e);
throw e;
return Row;
private static String getValue(Cell cell) {
String result = new String();
switch (cell.getCellType()) {
case HSSFCell.CELL_TYPE_NUMERIC:// 数字类型
System.out.println(cell.getCellStyle().getDataFormat());
if (HSSFDateUtil.isCellDateFormatted(cell)) {// 处理日期格式、时间格式
SimpleDateFormat sdf = null;
if (cell.getCellStyle().getDataFormat() == HSSFDataFormat.getBuiltinFormat("h:mm")) {
sdf = new SimpleDateFormat("HH:mm");
} else {// 日期
sdf = new SimpleDateFormat("yyyy-MM-dd");
Date date = cell.getDateCellValue();
result = sdf.format(date);
} else if (cell.getCellStyle().getDataFormat() == 181) {
SimpleDateFormat sdf = new SimpleDateFormat("yyyy-MM");
double value = cell.getNumericCellValue();
Date date = org.apache.poi.ss.usermodel.DateUtil.getJavaDate(value);
} else if (cell.getCellStyle().getDataFormat() == 58) {
// 处理自定义日期格式:m月d日(通过判断单元格的格式id解决,id的值是58)
SimpleDateFormat sdf = new SimpleDateFormat("yyyy-MM-dd");
} else {
CellStyle style = cell.getCellStyle();
// DecimalFormat format = new DecimalFormat();
// String temp = style.getDataFormatString();
// // 单元格设置成常规
// if (temp.equals("General")) {
// format.applyPattern("#");
// result = format.format(value);
result = value + "";
break;
case HSSFCell.CELL_TYPE_STRING:// String类型
result = cell.getRichStringCellValue().toString();
break;
case HSSFCell.CELL_TYPE_FORMULA:
result = cell.getNumericCellValue() + "";
break;
case HSSFCell.CELL_TYPE_BLANK:
result = "";
default:
result = "";
break;
return result;
```excel数据入库
复制代码
//readExcelrowKuaiBao是调用上面的方法
ArrayList> row = this.readExcelrowKuaiBao(fileName, filePath, 3, 4);
for (int i = 0; i < row.size(); i++) {
//获取第0列的值,也就是excel中第一列的值
row.get(i).get("column0").toString();
//获取第1列的值,列数依次累加
row.get(i).get("column1").toString();
[code][/code]
