JAVA多线程断点获取原理如图:
代码如下:
import java.io.BufferedReader;
import java.io.File;
import java.io.FileInputStream;
import java.io.InputStream;
import java.io.InputStreamReader;
import java.io.RandomAccessFile;
import java.net.HttpURLConnection;
import java.net.URL;
public class MutileThreadDownload {
* 线程的数量
private static int threadCount = 3;
* 每个获取区块的大小
private static long blocksize;
* 正在运行的线程的数量
private static int runningThreadCount;
* @param args
* @throws Exception
public static void main(String[] args) throws Exception {
// 服务器文件的路径
String path = "http://192.168.1.100:8080/ff.exe";
URL url = new URL(path);
HttpURLConnection conn = (HttpURLConnection) url.openConnection();
conn.setRequestMethod("GET");
conn.setConnectTimeout(5000);
int code = conn.getResponseCode();
if (code == 200) {
long size = conn.getContentLength();// 得到服务端返回的文件的大小
System.out.println("服务器文件的大小:" + size);
blocksize = size / threadCount;
// 1.首先在本地创建一个大小跟服务器一模一样的空白文件。
File file = new File("temp.exe");
RandomAccessFile raf = new RandomAccessFile(file, "rw");
raf.setLength(size);
// 2.开启若干个子线程分别去获取对应的资源。
runningThreadCount = threadCount;
for (int i = 1; i <= threadCount; i++) {
long startIndex = (i - 1) * blocksize;
long endIndex = i * blocksize - 1;
if (i == threadCount) {
// 最后一个线程
endIndex = size - 1;
System.out.println("开启线程:" + i + "获取的位置:" + startIndex + "~"
+ endIndex);
new DownloadThread(path, i, startIndex, endIndex).start();
conn.disconnect();
private static class DownloadThread extends Thread {
private int threadId;
private long startIndex;
private long endIndex;
private String path;
public DownloadThread(String path, int threadId, long startIndex,
long endIndex) {
this.path = path;
this.threadId = threadId;
this.startIndex = startIndex;
this.endIndex = endIndex;
@Override
public void run() {
try {
// 当前线程获取的总大小
int total = 0;
File positionFile = new File(threadId + ".txt");
.openConnection();
// 接着从上一次的位置继续获取数据
if (positionFile.exists() && positionFile.length() > 0) {// 判断是否有记录
FileInputStream fis = new FileInputStream(positionFile);
BufferedReader br = new BufferedReader(
new InputStreamReader(fis));
// 获取当前线程上次获取的总大小是多少
String lasttotalstr = br.readLine();
int lastTotal = Integer.valueOf(lasttotalstr);
System.out.println("上次线程" + threadId + "获取的总大小:"
+ lastTotal);
startIndex += lastTotal;
total += lastTotal;// 加上上次获取的总大小。
fis.close();
conn.setRequestProperty("Range", "bytes=" + startIndex + "-"
+ endIndex);
System.out.println("code=" + code);
InputStream is = conn.getInputStream();
// 指定文件开始写的位置。
raf.seek(startIndex);
System.out.println("第" + threadId + "个线程:写文件的开始位置:"
+ String.valueOf(startIndex));
int len = 0;
byte[] buffer = new byte[512];
while ((len = is.read(buffer)) != -1) {
RandomAccessFile rf = new RandomAccessFile(positionFile,
"rwd");
raf.write(buffer, 0, len);
total += len;
rf.write(String.valueOf(total).getBytes());
rf.close();
is.close();
raf.close();
} catch (Exception e) {
e.printStackTrace();
} finally {
// 只有所有的线程都获取完毕后 才可以删除记录文件。
synchronized (MutileThreadDownload.class) {
System.out.println("线程" + threadId + "获取完毕了");
runningThreadCount--;
if (runningThreadCount < 1) {
System.out.println("所有的线程都工作完毕了。删除临时记录的文件");
File f = new File(i + ".txt");
System.out.println(f.delete());
复制代码
以上就是本文的全部内容
