(一)Android6.0触摸事件分发机制解读
(二)Android6.0源码解读之View点击事件分发机制
(三)Android6.0源码解读之ViewGroup点击事件分发机制
(四)Android6.0源码解读之Activity点击事件分发机制
Android中通常点击事件用MotionEvent来表示,当一个点击操作发生时,事件最先传递给当前的Activity,由Activity的dispatchTouchEvent来进行事件的分发,具体工作是由Activity内部的Window来完成的。Window会将事件传递给decor view,decor view一般就是当前界面的底层容器(即setContentView所设置的View的父容器),通过Activity.getWindow.getDecorView()可以获得。关于Activity事件分发机制的源码,我们重点来看下dispatchTouchEvent方法。
(一)dispatchTouchEvent源码解析
* Called to process touch screen events. You can override this to
* intercept all touch screen events before they are dispatched to the
* window. Be sure to call this implementation for touch screen events
* that should be handled normally.
* @param ev The touch screen event.
* @return boolean Return true if this event was consumed.
public boolean dispatchTouchEvent(MotionEvent ev) { if (ev.getAction() == MotionEvent.ACTION_DOWN) { // 这是个空方法
onUserInteraction();
} //一开始事件交给Activity所附属的Window进行派发,如果返回true,整个事件循环就结束了,返回false意味着事件没人处理,所有人的onTouchEvent都返回了false,那么Activity就要来做最后的收场。
if (getWindow().superDispatchTouchEvent(ev)) { return true;
} return onTouchEvent(ev);
}123456789101112131415161718192021
onUserInteraction方法
* Called as part of the activity lifecycle when an activity is about to go
* into the background as the result of user choice. For example, when the
* user presses the Home key, {@LINK #onUserLeaveHint} will be called, but
* when an incoming phone call causes the in-call Activity to be automatically
* brought to the foreground, {@link #onUserLeaveHint} will not be called on
* the activity being interrupted. In cases when it is invoked, this method
* is called right before the activity's {@link #onPause} callback.
This callback and {@link #onUserInteraction} are intended to help
* activities manage status bar notifications intelligently; specifically,
* for helping activities determine the proper time to cancel a notfication.
* @see #onUserInteraction()
protected void onUserLeaveHint() {
(二)onTouchEvent源码解析
通常一个点击操作要是没有被Activity下的任何View处理,则Activity的onTouchEvent将会被调用。返回值为true表明你已经消费了这个事件,false则表示没有消费(默认)。
* Called when a touch screen event was not handled by any of the views
* under it. This is most useful to process touch events that happen
* outside of your window bounds, where there is no view to receive it.
* @param event The touch screen event being processed.
* @return Return true if you have consumed the event, false if you haven't.
* The default implementation always returns false.
public boolean onTouchEvent(MotionEvent event) { // mWindow对象其实就是dispatchTouchEvent方法里的getWindow()对象
if (mWindow.shouldCloseOnTouch(this, event)) {
finish(); return true;
} return false;
事件传递给ViewGroup
接下来我们看Window是如何将事件传递给ViewGroup的。通过源代码我们知道Window是一个抽象类,而Window的superDispatchTouchEvent方法也是个抽象方法,我们来看下。
* Used by custom windows, such as Dialog, to pass the touch screen event
* further down the view hierarchy. Application developers should
* not need to implement or call this.
public abstract boolean superDispatchTouchEvent(MotionEvent event);1234567
既然superDispatchTouchEvent是个抽象方法,那么我们去看下它的实现类PhoneWindow是如何处理点击事件的。
@Override public boolean superDispatchTouchEvent(MotionEvent event) { return mDecor.superDispatchTouchEvent(event);
}1234
通过以上源码不难发现,PhoneWindow将事件直接传递给了Decor View。我们来看下这里的DecorView。
private final class DecorView extends FrameLayout implements RootViewSurTaker
// This is the top-level view of the window, containing the window decor. private DecorView mDecor;
@Override
public final View getDecorView() { if (mDecor == null) {
installDecor();
} return mDecor;
}12345678910111213
通常我们通过((ViewGroup)getWindow().getDecorView().findViewById(android.R.id.content)).getChildAt(0)这种方式获取Activity所设置的View。这个mDecor显然就是getWindow().getDecorView()返回的View,而我们通过setContentView设置的View是它的一个子View。目前事件传递到了DecorView 这里,由于DecorView 继承自FrameLayout且是我们的父View,所以最终事件会传递给我们的View。从这里开始,事件已经传递到我们的顶级View了,所谓的顶级View实际上是最底层View,也叫根View。
