SpringBoot使用自定义json解析器的使用方法
 山东大明消毒科技有限公司
Spring-Boot是基于Spring框架的,它并不是对Spring框架的功能增强,而是对Spring的一种快速构建的方式。
Spring-boot应用程序提供了默认的json转换器,为Jackson。示例:
pom.xml中dependency配置:
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd">
<modelVersion>4.0.0</modelVersion>
<groupId>com.qinker</groupId>
<artifactId>spring-boot</artifactId>
<packaging>war</packaging>
<parent>
<groupId>org.springframework.boot</groupId>
<artifactId>spring-boot-starter-parent</artifactId>
<version>2.0.0.RELEASE</version>
</parent>
<version>0.0.1-SNAPSHOT</version>
<name>spring-boot</name>
<url>http://maven.apache.org</url>
<properties>
<project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
<java.version>9</java.version>
</properties>
<dependencies>
<!-- https://mvnrepository.com/artifact/org.springframework.boot/spring-boot-starter-web -->
<dependency>
<artifactId>spring-boot-starter-web</artifactId>
</dependency>
</dependencies>
<build>
<finalName>spring-boot</finalName>
</build>
</project>
复制代码
创建三个类:MainApp.java和User.java以及HelloController.java:
package com.springboot;
import java.util.Date;
import org.springframework.web.bind.annotation.RequestMapping;
import org.springframework.web.bind.annotation.RestController;
@RestController
public class HelloController {
@RequestMapping("/hello")
public String hello() {
return "hello,SpringBoot";
* Spring boot 默认json解析框架是Jackson
* @return
@RequestMapping("/getUser")
public User getUser() {
User u = new User();
u.setName("张三");
u.setAge(33);
u.setCreateTime(new Date());
return u;
复制代码
import java.io.Serializable;
public class User implements Serializable{
private String name;
private int age;
private Date createTime;
public String getName() {
return name;
public void setName(String name) {
this.name = name;
public int getAge() {
return age;
public void setAge(int age) {
this.age = age;
public Date getCreateTime() {
return createTime;
public void setCreateTime(Date createTime) {
this.createTime = createTime;
复制代码
import org.springframework.boot.SpringApplication;
import org.springframework.boot.autoconfigure.SpringBootApplication;
@SpringBootApplication
public class MainApp{
public static void main(String[] args) {
SpringApplication.run(MainApp.class, args);
复制代码
启动MainApp:访问http://localhost:8080/getUser,结果如下:
{"name":"张三","age":33,"createTime":"2018-04-04T03:03:08.534+0000"}
复制代码
可见:我们并未做任何配置,返回的却是json数据,可见Spring-Boot对json做了默认实现,使用的是内置Jackson转换器。
那么,下面看看如何使用自定义的json转换器,这里以fastjson为例:
首先,引入fastjson包,在pom中添加如下依赖:
<!-- https://mvnrepository.com/artifact/com.alibaba/fastjson -->
<dependency>
<groupId>com.alibaba</groupId>
<artifactId>fastjson</artifactId>
<version>1.2.47</version>
</dependency>
复制代码
为了方便看出效果:修改User类:
import com.alibaba.fastjson.annotation.JSONField;
@SuppressWarnings("serial")
private int age;
@JSONField(format="yyyy-MM-dd HH:mm")
return name;
this.name = name;
return age;
this.age = age;
return createTime;
复制代码
1.实现fastjson自定义json转换的第一种方式,Spring-Boot实现WebMvcConventer接口:
修改MainApp如下:
import java.util.ArrayList;
import java.util.List;
import org.springframework.http.MediaType;
import org.springframework.http.converter.HttpMessageConverter;
import org.springframework.web.servlet.config.annotation.WebMvcConfigurer;
import com.alibaba.fastjson.serializer.SerializerFeature;
import com.alibaba.fastjson.support.config.FastJsonConfig;
import com.alibaba.fastjson.support.spring.FastJsonHttpMessageConverter;
public class MainApp implements WebMvcConfigurer{
@Override
public void configureMessageConverters(List<HttpMessageConverter<?>> converters) {
WebMvcConfigurer.super.configureMessageConverters(converters);
//创建fastjson转换器实例
FastJsonHttpMessageConverter converter = new FastJsonHttpMessageConverter();
//配置对象
FastJsonConfig config = new FastJsonConfig();
List<MediaType> mediaTypes = new ArrayList<>();
//中文编码
MediaType mediaType = MediaType.APPLICATION_JSON_UTF8;
mediaTypes.add(mediaType);
config.setSerializerFeatures(SerializerFeature.PrettyFormat);
converter.setSupportedMediaTypes(mediaTypes);
converter.setFastJsonConfig(config);
converters.add(converter);
复制代码
启动程序:访问上面的路径:浏览器会看到如下结果:
"age":33,
"createTime":"2018-04-04 11:14",
"name":"张三"
复制代码
2.使用@Bean注解注入fastjson转换器:修改MainApp如下:
import org.springframework.boot.autoconfigure.http.HttpMessageConverters;
import org.springframework.context.annotation.Bean;
[url=home.php?mod=space&uid=4377]@Bean[/url]
public HttpMessageConverters fastJsonHttpMessageConventers() {
mediaTypes.add(MediaType.APPLICATION_JSON_UTF8);
return new HttpMessageConverters(converter);
复制代码
访问结果是一样的。
以上就是本文的全部内容,希望对大家的学习有所帮助,
