CSRF介绍
CSRF(Cross-site request forgery),中文名称:跨站请求伪造,也被称为:one click attack/session riding,缩写为:CSRF/XSRF。
具体SCRF的介绍和攻击方式请参看百度百科的介绍和一位大牛的分析:
CSRF百度百科
浅谈CSRF攻击方式
配置步骤
1.依赖jar包
<properties>
<spring.security.version>4.2.2.RELEASE</spring.security.version>
</properties>
<dependency>
<groupId>org.springframework.security</groupId>
<artifactId>spring-security-core</artifactId>
<version>${spring.security.version}</version>
</dependency>
<dependency>
<artifactId>spring-security-web</artifactId>
</dependency>
<dependency>
<artifactId>spring-security-config</artifactId>
</dependency>
复制代码
2.web.xml配置
<filter>
<filter-name>springSecurityFilterChain</filter-name>
<filter-class>org.springframework.web.filter.DelegatingFilterProxy</filter-class>
</filter>
<filter-mapping>
<url-pattern>/*</url-pattern>
</filter-mapping>
复制代码
3.Spring配置文件配置
<bean id="csrfSecurityRequestMatcher" class="com.xxx.CsrfSecurityRequestMatcher"></bean>
<security:http auto-config="true" use-expressions="true">
<security:headers>
<security:frame-options disabled="true"/>
</security:headers>
<security:csrf request-matcher-ref="csrfSecurityRequestMatcher" />
</security:http>
复制代码
4.自定义RequestMatcher的实现类CsrfSecurityRequestMatcher
这个类被用来自定义哪些请求是不需要进行拦截过滤的。如果配置csrf,所有http请求都被会CsrfFilter拦截,而CsrfFilter中有一个私有类DefaultRequiresCsrfMatcher。
源码1:DefaultRequiresCsrfMatcher类
private static final class DefaultRequiresCsrfMatcher implements RequestMatcher {
private final HashSet<String> allowedMethods;
private DefaultRequiresCsrfMatcher() {
this.allowedMethods = new HashSet(Arrays.asList(new String[]{"GET", "HEAD", "TRACE", "OPTIONS"}));
public boolean matches(HttpServletRequest request) {
return !this.allowedMethods.contains(request.getMethod());
复制代码
从这段源码可以发现,POST方法被排除在外了,也就是说只有GET|HEAD|TRACE|OPTIONS这4类方法会被放行,其它Method的http请求,都要验证_csrf的token是否正确,而通常post方式调用rest接口服务时,又没有_csrf的token,所以会导致我们的rest接口调用失败,我们需要自定义一个类对该类型接口进行放行。来看下我们自定义的过滤器:
源码2:csrfSecurityRequestMatcher类
public class CsrfSecurityRequestMatcher implements RequestMatcher {
private Pattern allowedMethods = Pattern.compile("^(GET|HEAD|TRACE|OPTIONS)$");
private RegexRequestMatcher unprotectedMatcher = new RegexRequestMatcher("^/rest/.*", null);
@Override
if(allowedMethods.matcher(request.getMethod()).matches()){
return false;
return !unprotectedMatcher.matches(request);
复制代码
说明:一般我们定义的rest接口服务,都带上 /rest/ ,所以如果你的项目中不是使用的这种,或者项目中没有rest服务,这个类完全可以省略的。
5.post请求配置
一般我们的项目中都有一个通用的jsp文件,就是每个页面都会引用的,所以我们可以在通用文件中做如下配置:
<meta name="_csrf" content="${_csrf.token}"/>
<meta name="_csrf_header" content="${_csrf.headerName}"/>
<script>
var token = $("meta[name='_csrf']").attr("content");
var header = $("meta[name='_csrf_header']").attr("content");
$.ajaxSetup({
beforeSend: function (xhr) {
if(header && token ){
xhr.setRequestHeader(header, token);
</script>
复制代码
$.ajaxSetup的意思就是给我们所有的请求都加上这个header和token,或者放到form表单中。注意,_csrf这个要与spring security的配置文件中的配置相匹配,默认为_csrf。
源码解析
我们知道,既然配置了csrf,所有的http请求都会被CsrfFilter拦截到,所以看下CsrfFilter的源码就对原理一目了然了。这里我们只看具体过滤的方法即可:
源码3:CsrfFilter的doFilterInternal方法
protected void doFilterInternal(HttpServletRequest request, HttpServletResponse response, FilterChain filterChain) throws ServletException, IOException {
request.setAttribute(HttpServletResponse.class.getName(), response);
CsrfToken csrfToken = this.tokenRepository.loadToken(request);
boolean missingToken = csrfToken == null;
if(missingToken) {//如果token为空,说明第一次访问,生成一个token对象
csrfToken = this.tokenRepository.generateToken(request);
this.tokenRepository.saveToken(csrfToken, request, response);
request.setAttribute(CsrfToken.class.getName(), csrfToken);
//把token对象放到request中,注意这里key是csrfToken.getParameterName()= _csrf,所以我们页面上才那么写死。
request.setAttribute(csrfToken.getParameterName(), csrfToken);
//这个macher就是我们在Spring配置文件中自定义的过滤器,也就是GET,HEAD, TRACE, OPTIONS和我们的rest都不处理
if(!this.requireCsrfProtectionMatcher.matches(request)) {
filterChain.doFilter(request, response);
} else {
String actualToken = request.getHeader(csrfToken.getHeaderName());
if(actualToken == null) {
actualToken = request.getParameter(csrfToken.getParameterName());
if(!csrfToken.getToken().equals(actualToken)) {
if(this.logger.isDebugEnabled()) {
this.logger.debug("Invalid CSRF token found for " + UrlUtils.buildFullRequestUrl(request));
if(missingToken) {
this.accessDeniedHandler.handle(request, response, new MissingCsrfTokenException(actualToken));
} else {
this.accessDeniedHandler.handle(request, response, new InvalidCsrfTokenException(csrfToken, actualToken));
} else {
复制代码
从源码中可以看到,通过我们自定义的过滤器以外的post请求都需要进行token验证。
以上就是本文的全部内容,希望对大家的学习有所帮助,
