手把手教你开发jquery插件(三)
 山东大明消毒科技有限公司
First, i want to add options to Tabs constructor like this:
var tabs = $("div.tabs").tabs({
       "openEvent": "mouseover",
       "disabled": [1, 2],
       "current": 3
These options are borrowed from jQuery UI
Tabs:
openEvent:(String,"click")
       The type of event to be used for selecting a tab.
   disabled:(Array,[])
       An array containing the position of the tabs (zero-based index) that should be disabled on initialization.
   current:(Number,0)
       Zero-based index of the tab to be selected on initialization. To set all tabs to unselected pass -1 as value.
The plugin code:
(function($) {
       function Tabs(tabs, panes, options) {
           var that = this;
           this.options = {
               "disabled": [],
               "current": 0
           $.extend(this.options, options);
           this.tabs = tabs.removeClass("current");
           this.panes = panes.hide();
           this.current = this.options.current;
           this.openTab(this.current);
           this.tabs[this.options.openEvent](function() {
               that.openTab(that.tabs.index(this));
       Tabs.prototype = {
           openTab: function(index) {
               this.current = index;
               if (this.current !== -1 && $.inArray(this.current, this.options.disabled) === -1) {
                   this.tabs.removeClass("current").eq(this.current).addClass("current");
                   this.panes.hide().eq(this.current).show();
       $.fn.tabs = function(options) {
           var tabs = this.children("ul").find("li > a");
           var panes = this.children("div");
           return new Tabs(tabs, panes, options);
Second, add some events to the plugin like this:
       "disabled": [1, 2],
       "current": 3,
       "events": {
           "open": function(event, index) {
               console.log("[events-open]You click tab " + index);
The plugin source code:
(function($) {
           var that = this;
           this.options = {
               "disabled": [],
               "current": 0,
               "events": {}
           $.each(this.options.events, function(key, value) {
               $(that).bind(key, value);
           // Open current tab
           // Register open tab event
       Tabs.prototype = {
                   $(this).trigger("open", [this.current]);
The result:
   [events-open]You click tab 3
   [events-open]You click tab 4
   [events-open]You click tab 0
Notice: In this section, we bind event to a JavaScript object not the jQuery object,
which i have mentioned in my last article.
Third, add some methods so that we can invoke like this:
tabs.bind("open", function(event, index) {
       console.log("[bind-open]You click tab " + index);
Source code:
Tabs.prototype = {
       bind: function(name, fn) {
           $(this).bind(name, fn);
The result:
   [bind-open]You click tab 4
   [bind-open]You click tab 3
   [bind-open]You click tab 0
Well, this series of tutorials has been finished. Pretty simple, isn’t it?
