jQuery tips and tricks
 山东大明消毒科技有限公司
1. How to judge element is visible ?
   if($(".nav").is(":visible")) {
       // This element is visible
This filter is very power, for example:
This element is hidden.
   if ($("#test").is(":hidden")) {
       alert("this element is hidden"); // execute
Inside the jQuery, it use offsetWidth and offsetHeight to judge whether an element
is visible, not through CSS properties visibility or display:
   Sizzle.selectors.filters.visible = function(elem){
   return elem.offsetWidth > 0 || elem.offsetHeight > 0;
2. Scroll to an element
   // This example doesn't work properly
   var eleTop = $("#p2").offset().top;
   $("body").scrollTop(eleTop);
OK, it’s a trick that we must set selecter to “html, body”:
   // Works well
   $("html, body").scrollTop(eleTop);
Add some animations:
   $("html, body").animate({
       "scrollTop": eleTop
   }, "slow");
3. Another way to find the index of an element within a set
In the previous
article, I use the jQuery index method to achieve this.
Below are some other ways:
menu 1
menu 2
menu 3
   // Previous method
   var lis = $("ul.menu li").click(function() {
       lis.index(this); // "menu 3" -> 2
   // Method 1
       alert($(this).prevAll().length); // "menu 3" -> 2
   // Method 2
       alert(lis.length - $(this).nextAll().length - 1);
   // Method 3
       alert($.inArray(this, lis));
4. Loop in a graceful way - $.each
We may loop through object or array like this:
   var obj = {
       "name": "zhangsan",
       "sex": "man",
       "age": 21
   for (var i in obj) {
       console.log("key:" + i + " value:" + obj[i]);
   var arr = ["zhangsan", "lisi", "wanger"];
   for (var i = 0; i < arr.length; i++) {
       console.log("index:" + i + " value:" + arr[i]);
Now, with jQuery:
   // key:name value:zhangsan
   // key:sex value:man
   // key:age value:21
   $.each(obj, function(i, item) {
       console.log("key:" + i + " value:" + item);
   // index:0 value:zhangsan
   // index:1 value:lisi
   // index:2 value:wanger
   $.each(arr, function(i, item) {
       console.log("index:" + i + " value:" + item);
4. Return false to prevent default and stop propagation
       Go to Google
   $("#link1").click(function(event) {
       alert("click link1.");
   // 1. Only prevent default action of hyperlink, the alert dialog is showing.
   $("#link1 a").click(function(event) {
       event.preventDefault();
   // 2. No alert dialog shows
       event.stopPropagation();
   // 3. This is the same as previous code
       return false;
