公 制 粗 螺 纹 | |||
规格 | 标准径 | 2级牙钻孔径 | |
最大 | 最小 | ||
M1.0×0.25 | 0.75 | 0.785 | 0.729 |
M1.1×0.25 | 0.85 | 0.885 | 0.829 |
M1.2×0.25 | 0.95 | 0.985 | 0.929 |
M1.4×0.3 | 1.10 | 1.142 | 1.075 |
M1.6×0.35 | 1.25 | 1.321 | 1.221 |
M1.7×0.35 | 1.35 | 1.421 | 1.321 |
M1.8×0.35 | 1.45 | 1.521 | 1.421 |
M2.0×0.4 | 1.60 | 1.679 | 1.567 |
M2.2×0.45 | 1.75 | 1.838 | 1.713 |
M2.3×0.4 | 1.90 | 1.979 | 1.867 |
M2.5×0.45 | 2.10 | 2.138 | 2.013 |
M2.6×0.45 | 2.20 | 2.238 | 2.113 |
M3.0×0.5 | 2.50 | 2.599 | 2.459 |
M3.0×0.6 | 2.40 | 2.44 | 2.280 |
M3.5×0.6 | 2.90 | 3.010 | 2.850 |
M4.0×0.7 | 3.30 | 3.422 | 3.242 |
M4.0×0.75 | 3.25 | 3.326 | 3.106 |
M4.5×0.75 | 3.80 | 3.878 | 3.688 |
M5.0×0.8 | 4.20 | 4.334 | 4.134 |
M5.0×0.9 | 4.10 | 4.170 | 3.930 |
M6.0×1.0 | 5.00 | 5.153 | 4.917 |
M7.0×1.0 | 6.00 | 6.153 | 5.917 |
M8.0×1.25 | 6.80 | 6.912 | 6.647 |
M9.0×1.25 | 7.80 | 7.912 | 7.647 |
M10×1.5 | 8.50 | 8.676 | 8.376 |
M11×1.5 | 9.50 | 9.676 | 9.376 |
M12×1.75 | 10.30 | 10.441 | 10.106 |
M14×2.0 | 12.00 | 12.210 | 11.735 |
M16×2.0 | 14.00 | 14.210 | 13.835 |
M18×2.5 | 15.50 | 15.744 | 15.294 |
M20×2.5 | 17.50 | 17.744 | 17.294 |
M22×2.5 | 19.50 | 19.744 | 19.294 |
M24×3.0 | 21.00 | 21.252 | 2.752 |
M27×3.0 | 24.00 | 24.252 | 23.752 |
M30×3.5 | 26.50 | 26.771 | 26.211 |
公 制 细 螺 纹 | |||
最大 | 最小 | ||
M1.0×0.2 | 0.80 | 0.821 | 0.783 |
M1.1×0.2 | 0.90 | 0.921 | 0.883 |
M1.2×0.2 | 1.00 | 1.021 | 0.983 |
M1.4×0.2 | 1.20 | 1.221 | 0.183 |
M1.6×0.2 | 1.40 | 1.421 | 1.383 |
M1.7×0.2 | 1.45 | 1.500 | 1.460 |
M1.8×0.2 | 1.60 | 1.621 | 1.583 |
M2.0×0.25 | 1.75 | 1.785 | 1.729 |
M2.2×0.25 | 1.95 | 1.985 | 1.929 |
M2.3×0.25 | 2.05 | 2.061 | 2.001 |
M2.5×0.35 | 2.20 | 2.221 | 2.121 |
M2.6×0.35 | 2.20 | 2.246 | 2.186 |
M3.0×0.35 | 2.70 | 2.721 | 2.621 |
M3.5×0.35 | 3.20 | 3.221 | 3.121 |
M4.0×0.5 | 3.50 | 3.599 | 3.459 |
M4.5×0.5 | 4.00 | 4.099 | 3.959 |
M5×0.5 | 4.50 | 4.599 | 4.459 |
M5.5×0.5 | 5.00 | 5.099 | 4.959 |
M6.0×0.75 | 5.30 | 5.378 | 5.188 |
M6.0×0.5 | 5.50 | 5.550 | 5.400 |
M7.0×0.75 | 6.30 | 6.378 | 61.88 |
M7.0×0.5 | 6.50 | 6.550 | 64.00 |
M8.0×1.0 | 7.00 | 7.153 | 6.917 |
M8.0×0.75 | 7.30 | 7.378 | 7.188 |
M8×0.5 | 7.50 | 7.520 | 7.400 |
M9×1.0 | 8.00 | 8.153 | 7.917 |
M9×0.75 | 8.30 | 8.378 | 8.188 |
M10×1.25 | 8.80 | 8.912 | 8.647 |
M10×1.0 | 9.00 | 9.153 | 8.917 |
M10×0.75 | 9.30 | 9.378 | 9.188 |
M10×0.5 | 9.50 | 9.520 | 9.400 |
M11×1.0 | 10.00 | 10.153 | 9.917 |
M11×0.75 | 10.30 | 10.378 | 10.188 |
M11×1.5 | 10.50 | 10.676 | 10.376 |
M12×1.25 | 10.80 | 10.912 | 10.647 |
公 制 细 螺 纹 | |||
最大 | 最小 | ||
M12×1.0 | 11.00 | 11.153 | 10.917 |
M12×0.5 | 11.50 | 11.520 | 11.4 |
M14×1.5 | 12.50 | 12.676 | 12.376 |
M14×1.0 | 13.00 | 13.153 | 12.917 |
M15×1.5 | 13.50 | 13.676 | 13.376 |
M15×1.0 | 14.00 | 14.153 | 13.917 |
M16×1.5 | 14.50 | 14.676 | 14.376 |
M16×1.0 | 15.00 | 15.153 | 14.917 |
M17×1.5 | 15.50 | 15.676 | 15.376 |
M17×1.0 | 16.00 | 16.153 | 15.917 |
M18×2.0 | 16.00 | 16.210 | 15.835 |
M18×1.5 | 16.50 | 16.670 | 16.376 |
M18×1.0 | 17.00 | 17.153 | 16.917 |
M20×2.0 | 18.00 | 18.210 | 17.835 |
M20×1.5 | 18.50 | 18.676 | 18.376 |
M20×1.0 | 19.00 | 19.153 | 18.917 |
M20×2.0 | 20.00 | 20.210 | 19.835 |
M22×1.5 | 20.50 | 20.676 | 20.376 |
M22×1.0 | 21.00 | 21.153 | 20.917 |
M24×2.0 | 22.00 | 22.210 | 21.835 |
M24×1.5 | 22.50 | 22.676 | 22.376 |
M24×1.0 | 23.00 | 23.153 | 22.917 |
M25×2.0 | 23.00 | 23.210 | 22.835 |
M25×1.5 | 23.50 | 23.676 | 23.376 |
M25×1.0 | 24.00 | 24.153 | 23.917 |
M26×1.5 | 24.50 | 24.676 | 24.376 |
M27×2.0 | 25.00 | 25.210 | 24.835 |
M27×1.5 | 25.50 | 25.676 | 25.376 |
M27×1.0 | 26.00 | 26.153 | 25.917 |
M28×2.0 | 26.00 | 26.210 | 25.835 |
M28×1.5 | 26.50 | 26.676 | 26.376 |
M28×1.0 | 27.00 | 27.153 | 26.917 |
M30×3.0 | 27.00 | 27.252 | 26.752 |
M30×2.0 | 28.00 | 28.210 | 27.835 |
M30×1.5 | 28.50 | 28.676 | 28.376 |
M30×1.0 | 29.00 | 29.153 | 28.917 |
M32×2.0 | 30.00 | 30.210 | 29.835 |
M32×1.5 | 30.50 | 30.676 | 30.376 |
M33×3.0 | 30.00 | 30.252 | 29.752 |
M33×2.0 | 31.00 | 31.210 | 30.835 |
M33×1.5 | 31.50 | 31.376 | 31.376 |
M35×1.5 | 33.50 | 33.676 | 33.376 |
M36×3.0 | 33.00 | 33.252 | 32.752 |
M36×2.0 | 34.00 | 34.210 | 33.835 |
M36×1.5 | 34.50 | 34.676 | 34.376 |
美 制 细 螺 纹 | |||
规格(UNF) | 标准径 | 2级牙钻孔径 | |
最大 | 最小 | ||
番数牙外径 | |||
NO.0-80(1.524) | 1.25 | 1.305 | 1.182 |
NO.1-72(1.854) | 1.55 | 1.612 | 1.474 |
NO.2-64(2.184) | 1.85 | 1.912 | 1.756 |
NO.3-56(2.515) | 2.10 | 2.197 | 2.025 |
NO.4-48(2.845) | 2.40 | 2.458 | 2.271 |
NO.5-44(3.175) | 2.70 | 2.740 | 2.551 |
NO.6-40(3.505) | 2.90 | 3.022 | 2.820 |
NO.8-36(4.166) | 3.50 | 3.606 | 3.404 |
NO.10-32(4.826) | 4.10 | 4.165 | 3.963 |
NO.12-28(5.846) | 4.60 | 4.724 | 4.496 |
1/4 -28 | 5.50 | 5.588 | 5.360 |
5/16 -24 | 6.90 | 7.035 | 6.782 |
3/8 -24 | 8.50 | 8.636 | 8.382 |
7/16 -20 | 9.90 | 10.033 | 9.729 |
1/2 -20 | 11.50 | 11.607 | 11.329 |
9/16 -18 | 12.90 | 13.081 | 12.751 |
5/8 -18 | 14.50 | 14.681 | 14.351 |
3/4 -16 | 17.50 | 14.678 | 17.323 |
7/8 -14 | 20.50 | 20.675 | 20.270 |
1 -12 | 23.20 | 23.571 | 23.114 |
1-1/8 -12 | 26.50 | 26.746 | 26.289 |
1-1/4 -12 | 29.50 | 29.921 | 29.464 |
1-3/8 -12 | 32.80 | 33.096 | 32.464 |
1-1/2 -12 | 36.00 | 36.270 | 35.814 |
无 屑 丝 攻 钻 孔 径 | |||
规格 | 精度等级 | ||
RH4.5.6 | RH7.8 | RH9 | |
M1.0×0.25 | 0.86 | 0.88 | - |
M1.1×0.25 | 0.96 | 0.98 | - |
M1.2×0.25 | 1.06 | 1.08 | - |
M1.4×0.3 | 1.24 | 1.25 | - |
M1.6×0.35 | 1.41 | 1.43 | - |
M1.7×0.35 | 1.51 | 1.53 | - |
M1.8×0.35 | 1.61 | 1.63 | - |
M2.0×0.4 | 1.78 | 1.80 | - |
M2.2×0.45 | 1.95 | 1.98 | - |
M2.3×0.4 | 2.08 | 2.10 | - |
M2.5×0.45 | 2.25 | 2.28 | - |
M2.6×0.45 | 2.35 | 1.38 | - |
M3.0×0.5 | 2.73 | 2.75 | - |
M3.0×0.6 | 3.17 | 3.20 | - |
M4.0×0.7 | 3.62 | 3.65 | 3.69 |
M5.0×0.8 | 4.56 | 4.60 | 4.64 |
M6.0×1.0 | 5.45 | 5.50 | 5.55 |
M7.0×1.0 | 6.45 | 6.50 | 6.55 |
M8.0×1.25 | 7.31 | 7.38 | 7.44 |
M10×1.5 | 9.18 | 9.25 | 9.32 |
M10×1.25 | 9.31 | 9.38 | 9.44 |
M12×1.75 | 11.04 | 11.12 | 11.21 |
M12×1.25 | 11.31 | 11.38 | 11.44 |
注:无槽丝攻之钻孔径,在上表所列之数值,由于被加工材料之材质、硬度、形状、尺寸等之影响,多少会有所变动,因此参考上表之同时,亦请增减若干. | |||
美 制 管 螺 纹 | |||
规格(UNEF) | 标准径 | 2级牙钻孔径 | |
最大 | 最小 | ||
NO.12 -32 | 4.70 | 4.826 | 4.623 |
1/4 -32 | 5.60 | 5.690 | 5.486 |
5/16 -32 | 7.10 | 7.264 | 7.087 |
3/8 -32 | 8.70 | 8.865 | 8.661 |
7/16 -28 | 10.20 | 10.338 | 10.135 |
1/2 -28 | 11.80 | 11.938 | 11.709 |
9/16 -28 | 13.20 | 13.386 | 13.132 |
5/8 -24 | 14.80 | 14.986 | 14.732 |
3/4 -20 | 17.80 | 17.958 | 17.678 |
7/8 -20 | 21.00 | 21.133 | 20.853 |
1 -20 | 24.00 | 24.308 | 24.028 |
美 制 粗 螺 纹 | |||
规格(UNC) | 标准径 | 2级牙钻孔径 | |
番数牙外径 | 最大 | 最小 | |
NO.1-64(1.854) | 1.55 | 1.582 | 1.425 |
NO.2-56(2.184) | 1.80 | 1.871 | 1.695 |
NO.3-48(2.515) | 2.10 | 2.146 | 1.941 |
NO.4-40(2.845) | 2.30 | 2.385 | 2.157 |
NO.5-40(3.175) | 2.60 | 2.697 | 2.487 |
NO.6-32(3.505) | 2.80 | 2.895 | 2.642 |
NO.8-32(4.166) | 3.40 | 3.530 | 3.302 |
NO.10-24(4.826) | 3.90 | 3.962 | 3.682 |
NO.12-24(5.846) | 4.50 | 4.597 | 4.344 |
1/4 -20 | 5.10 | 5.257 | 4.979 |
5/16 -18 | 6.60 | 6.731 | 6.401 |
3/8 -16 | 8.00 | 8.153 | 7.987 |
7/16 -14 | 9.40 | 9.500 | 9.144 |
1/2 -13 | 10.80 | 11.023 | 10.592 |
9/16 -12 | 12.20 | 12.446 | 11.989 |
5/8 -11 | 13.60 | 12.868 | 13.386 |
3/4 -10 | 16.20 | 16.840 | 16.307 |
7/8 -9 | 19.50 | 19.761 | 19.177 |
1 -8 | 22.20 | 22.606 | 21.971 |
1-1/8 -7 | 25.00 | 25.349 | 24.638 |
1-1/4 -7 | 28.20 | 28.524 | 27.813 |
1-3/8 -6 | 30.80 | 31.115 | 30.353 |
1-1/2 -6 | 34.00 | 34.290 | 33.528 |
1-3/4 -5 | 39.50 | 39.827 | 38.964 |
2 -4-1/2 | 45.20 | 45.593 | 44.679 |
英 制 螺 纹 | |||||
规格 | 钻孔径 | ||||
硬材 | 软材 | ||||
W1/8 - 40 | 2.65 | 2.60 | |||
W5/32 - 32 | 3.25 | 3.20 | |||
W3/16 - 24 | 3.75 | 3.70 | |||
W1/4 - 20 | 5.10 | 5.00 | |||
W5/16 - 18 | 6.60 | 6.50 | |||
W3/8 - 16 | 8.00 | 7.90 | |||
W7/16 - 14 | 9.40 | 9.30 | |||
W1/2 - 12 | 10.70 | 10.50 | |||
W9/16 - 12 | 12.30 | 12.00 | |||
W5/8 - 11 | 13.70 | 13.50 | |||
W3/4 - 10 | 16.70 | 16.50 | |||
W7/8 - 9 | 19.50 | 19.30 | |||
W1 - 8 | 22.40 | 22.00 | |||
W1-1/8 - 7 | 25.00 | 24.80 | |||
W1-1/4 - 7 | 28.30 | 28.00 | |||
英 制 管 螺 纹 | |||||
规格 | 标准径 | 钻 孔 径 | |||
最大 | 最小 | ||||
PS1/16 -28 | 6.50 | 6.632 | 6.490 | ||
PS1/8 -28 | 8.50 | 8.637 | 8.495 | ||
PS1/4 - 19 | 11.40 | 11.549 | 11.341 | ||
PS3/8 - 19 | 15.00 | 15.054 | 14.846 | ||
PS1/2 - 14 | 18.50 | 18.773 | 18.489 | ||
PS3/4 - 14 | 24.00 | 24.259 | 23.975 | ||
PS1 - 11 | 30.20 | 30.471 | 30.111 | ||
PS1-1/4 -11 | 38.80 | 39.132 | 38.772 | ||
PS1-1/2 -11 | 44.80 | 45.025 | 44.665 | ||
PS2 - 11 | 56.50 | 56.836 | 56.476 | ||
英 制 管 螺 纹 | |||||
规格 | 标准径 | 有效牙部之长度(最小)中之母螺牙内径 | 标准长度(最小)中之母螺牙内径 | ||
使用绞刀时 | 不用绞刀时 | ||||
PT1/16 -28 | 6.10 | 6.2 | 6.244 | 6.384 | |
PT1/8 -28 | 8.10 | 8.2 | 8.249 | 8.388 | |
PT1/4 -19 | 10.70 | 11 | 10.962 | 11.174 | |
PT3/8 -19 | 14.20 | 14.5 | 14.448 | 14.658 | |
PT1/2 -14 | 17.60 | 18 | 17.979 | 18.263 | |
PT3/4 -14 | 23.00 | 23.5 | 23.378 | 23.663 | |
Pt1 -11 | 29.00 | 29.5 | 29.459 | 29.822 | |
PT1-1/4 -11 | 37.50 | 38 | 37.976 | 38.339 | |
PT1-1/2 -11 | 43.40 | 44 | 43.869 | 44.232 | |
Pt2 -11 | 54.90 | 55.5 | 55.412 | 55.844 | |
美 制 螺 纹 滚 造 径 | |||||
规格 | 钻孔径 | ||||
NPT | NPS | ||||
1/16 -27 | 6.1 | 6.25 | 6.35 | ||
1/8 -27 | 8.33 | 8.43 | 8.74 | ||
1/4 -18 | 10.72 | 11.13 | 11.13 | ||
3/8 -18 | 14.27 | 14.27 | 14.68 | ||
1/2 -14 | 17.48 | 17.86 | 18.26 | ||
3/4 -14 | 22.63 | 23.01 | 23.42 | ||
1 -11-1/2 | 28.58 | 28.98 | 29.36 | ||
1-1/4-11-1/2 | 37.31 | 37.69 | 38.1 | ||
1-1/2-11-1/2 | 43.66 | 44.04 | 44.45 | ||
2 -11-1/2 | 55.58 | 55.96 | 56.36 | ||
英 制 螺 纹 滚 造 径 | |||||
规格 | 滚造径 | ||||
W 3/16 - 24 | 4.08 - 4.05 | ||||
W 1/4 - 20 | 5.51 - 5.46 | ||||
W 5/16 - 18 | 7.01 - 6.95 | ||||
W 3/8 - 16 | 8.48 - 8.41 | ||||
W 7/16 - 14 | 9.92 - 9.85 | ||||
W 1/2 - 12 | 11.31 - 11.24 | ||||
W 9/16 -12 | 12.89 - 12.82 |
公 制 螺 纹 | ||
规格 | 滚造径 | |
M3.0×0.5 | 2.63 2.60 | |
M3.0×0.6 | 2.56 2.53 | |
M3.5×0.6 | 3.06 3.03 | |
M4.0×0.7 | 3.49 3.45 | |
M4.0×0.75 | 3.45 3.41 | |
M4.5×0.75 | 3.96 3.92 | |
M5.0×0.8 | 4.43 4.38 | |
M5.0×0.9 | 4.36 4.31 | |
M6.0×1.0 | 5.30 5.25 | |
M7.0×1.0 | 6.30 6.25 | |
M8.0×1.0 | 7.28 - 7.23 | |
M8.0×1.25 | 7.12 - 7.07 | |
M9.0×1.25 | 8.12 - 8.07 | |
M10×1.25 | 9.10 - 9.04 | |
M10×1.5 | 8.97 - 8.91 | |
M11×1.5 | 9.97 - 9.91 | |
M12×1.5 | 10.92 - 10.87 | |
M12×1.75 | 10.79 - 10.73 | |
M14×2.0 | 12.63 - 12.56 | |
M16×2.0 | 14.63 - 14.56 | |
M18×2.5 | 16.31 - 16.23 | |
M20×2.5 | 18.31 - 18.23 | |
M22×2.5 | 20.31 - 20.23 | |
针 车 用 螺 纹 | ||
规格(UNC) | 滚造径 | |
SM 1/8 40 | 2.735 -2.688 | |
SM 1/8 44 | 2.769 -2.722 | |
SM 9/64 40 | 3.128 -3.083 | |
SM 11/64 40 | 3.855 -3.805 | |
SM 3/16 32 | 4.205 -4.155 | |
SM 3/16 28 | 4.143 -4.093 | |
SM 7/32 32 | 5.003 -4.955 | |
SM 15/64 28 | 5.325 -4.955 | |
SM 1/4 40 | 5.890 -5.735 | |
SM 1/4 28 | 5.721 -5.366 | |
SM 9/32 28 | 6.528 -6.648 | |
SM 11/32 28 | 8.092 -8.432 | |
SM 3/8 29 | 8.880 -8.015 | |
SM 7/16 30 | 10.466 -10.401 | |
SM 7/16 16 | 10.037 -9.967 | |
SM 1/2 20 | 11.819 -11.749 | |
SM 9/16 20 | 13.400 -13.425 | |
美 制 粗 螺 纹 | ||
规格(UNC) | 滚造径 | |
NO.5-40 | 2.70 - 2.67 | |
NO.6-32 | 2.95 - 2.91 | |
NO.8-32 | 3.60 - 3.57 | |
NO.10-24 | 4.09 - 4.05 | |
NO.12-24 | 4.75 - 4.70 | |
1/4 -20 | 5.50 - 5.45 | |
5/16 -18 | 6.98 - 6.93 | |
3/8 -16 | 8.45 - 8.40 | |
7/16 -14 | 9.89 - 9.83 | |
1/2 -13 | 11.39 - 11.32 | |
9/16 -12 | 12.87 - 12.80 | |
美 制 细 螺 纹 | ||
规格(UNF) | 滚造径 | |
NO.5-44 | 2.73 - 2.70 | |
NO.6-40 | 3.05 - 3.02 | |
NO.8-36 | 3.66 - 3.63 | |
NO.10-32 | 4.26 - 4.80 | |
NO.12-28 | 4.84 - 4.80 | |
1/4 -28 | 5.72 - 5.68 | |
5/16 -24 | 7.20 - 7.16 | |
3/8 -24 | 8.79 - 8.74 | |
7/16 -20 | 10.23 - 10.18 | |
1/2 -20 | 11.82 - 11.76 |
