如何在Start-Job的Scriptblock里传参?
方法1:
利用本地变量,从一个可扩展的字符串,使用[scriptblock]::create方法创建脚本块:
$v1 = "123"$v2 = "asdf"$sb = [scriptblock]::Create("Write-Host 'Values are: $v1, $v2'")$job = Start-Job -ScriptBlock $sb# 另一种写法[scriptblock]$sb ={Write-Host "Values are: $v1, $v2"}复制代码
方法2:
在InitializationScript中设置变量
$Init_Script = {$v1 = "123"$v2 = "asdf"}$sb = {Write-Host "Values are: $v1, $v2"}$job = Start-Job -InitializationScript $Init_Script -ScriptBlock $sb复制代码
方法3:
使用-Argumentlist参数
$v1 = "123"$v2 = "asdf"$sb = {Write-Host "Values are: $($args[0]), $($args[1])"}$job = Start-Job -ScriptBlock $sb -ArgumentList $v1,$v2复制代码
