实验步骤:
把r1与r2配置连通
r1(config)#Int e0/0
r1(config-if)#Ip
add 12.0.0.1 255.255.255.0
r1(config-if)#no shu
r2(config)#Int e0/0
r2(config-if)#Ip add 12.0.0.2 255.255.255.0
r2(config-if)#no shu
实验过程:
1.在r1上的配置:
r1(config)#Dial-peer voice 1 pots//配置语音与对等体关联
r1(config-dial-peer)#Port 1/1/1
//把物理语音接口分配到一个pots拨号对等体
r1(config-dial-peer)#Destijation-pattern 123
//把电话号码123与pots语音端口关联起来
r1(config-dial-peer)#exi
r1(config)#Dial-peer voice 2 voip
r1(config-dial-peer)#Destination-pattern 321
//远程的电话号码
r1(config-dial-peer)#Session target ipv4 :12.0.0.2
//当路由器r1从语音端口收到321时,将把这些数字匹配到对等体2上,并指示路由器r1把呼叫转发到voip对等体192.168.0.2
2.在r2上的配置:
r2(config)#Dial-peer voice 1 pots
r2(config-dial-peer)#Port 1/1/1
r2(config-dial-peer)#Destijation-pattern
321
r2(config-dial-peer)#exi
r2(config)#Dial-peer voice 2 voip
r2(config-dial-peer)#Destination-pattern 123
r2(config-dial-peer)#Session target ipv4 :12.0.0.1
