路由器日常维护和排错
 辽宁辽环认证中心
路由器日常维护和排错
通常我们使用show inter命令来查看接口的信息,如show inter gig 1/0或者show int pos 2/0等来分别查看路由器上千兆以太接口和POS接口的端口信息。
查看以太网接口信息,在7507上使用命令为: show inters fastethernet [slot/port-adapter/port]
查看POS接口信息,在7507上使用命令为: show inters pos [slot/port-adapter/port]
1、下例给出了在7507上查看第1槽位上第1个PA上的第1个快速以太网接口的接口配置信息:
Router# show inters fastethernet 1/0/0
Fast Ethernet1/0/0 is up, line protocol is up
Hardware is TSWITCH, address is 00e0.f7a4.5130 (bia 00e0.f7a4.5130)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, rely 255/255, load 1/255
Encapsulation ARPA, loopback not set, keepalive set (10 sec)
Half-duplex, 100BaseTX
ARP type: ARPA, ARP Timeout 04:00:00
Last input 00:05:30, output 00:00:00, output hang never
Last clearing of "show inter" counters never
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 0 bits/sec, 0 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
312 packets input, 18370 bytes, 0 no buffer
Received 216 broadcasts, 0 runts, 0 giants, 0 throttles
3 input errors, 0 CRC, 0 frame, 0 overrun, 3 ignored, 0 abort
0 input packets with dribble condition detected
15490 packets output, 1555780 bytes, 0 underruns
2 output errors, 0 collisions, 2 inter resets
0 babbles, 0 late collision, 0 deferred
0 lost carrier, 0 no carrier
2 output buffer failures, 0 output buffers swapped out
2、下例给出了在7507上查看第2槽位上第1个PA上的第1个快速以太网接口的接口配置信息:
Router# show inters pos 2/0/0
POS2/0/0 is up, line protocol is up
Hardware is cyBus Packet over Sonet
Description: PRI-T1 net to zippy (4K) to Pac-Bell
Internet address is 10.1.1.1/27
MTU 4470 bytes, BW 1000 Kbit, DLY 40000 usec, rely 255/255, load 1/255
Encapsulation HDLC, loopback not set, keepalive set (3 sec)
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show inter" counters 00:23:09
5 minute input rate 0 bits/sec, 1 packets/sec
5 minute output rate 1000 bits/sec, 1 packets/sec
1046 packets input, 54437 bytes, 0 no buffer
Received 485 broadcasts, 0 runts, 0 giants, 0 parity
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
4013 packets output, 1357412 bytes, 0 underruns
0 output errors, 0 applique, 0 inter resets
0 output buffer failures, 0 output buffers swapped out
0 carrier transitions
3、下表给出了show inter的输出中所有表项的具体含义:
表项
描述
Fast Ethernet... is up
...is administratively down
表明接口的硬件当前是否是被激活的还是被管理员手工的showdown掉了。
line protocol is
标识该接口的线协议也就是软件进程是否可用,还是被管理员手工的给shutdown了。
Hardware
硬件类型(例如MCI Ethernet, SCI, cBus Ethernet) 和硬件地址
Internet address
带有子网信息的该接口的IP地址。
MTU
接口上的最大传输单元。
BW
接口的带宽,通常单位是kb/s。
DLY
端口的延迟,单位是ms。
rely
以255为参照数的接口的可靠性参数 (255/255 就是百分之百的可靠), 以5分钟的平均数来计算。
load
以255为参照数的接口的负荷(255/255 就是百分之百的负荷量), 5分钟的平均数来计算。
Encapsulation
接口的封装类型。
ARP type
接口配置的地址解析协议(ARP)的类型。
loopback
标识是否设置了接口回环。
keepalive
标识接口是否设置了发送存活(keepalives)信息
Last input
自从接口接受到最近的一个数据包后的时间。当该数据包是被precess-switch的方式转发的时候计数器会更新,而当该包是被fast-switch的方式转发时则不更新计数器。
output
自从接口发送最近的一个数据包后的时间。
output hang
接口因为数据包传输时间过长而重启后的时间,如果没有重启,则显示为never。
Last clearing
清除接口统计计数器后的时间。注意:可能会影响到路由的变量信息时不会被清除置0的,例如load和reliablity
型号***表示清计算器后的时间太长显示不出来了。
Output queue, input queue, drops
在接口输入输出队列中的数据包的个数。每个数字都跟了个/队列的最大范围。以及超过了队列的最大范围而丢弃的包的数量。
5 minute input rate,
在最近5分钟内每秒传输的数据包的平均值。
packets input
系统接受到的数据包的总的个数。
bytes
系统接受到的所有数据包(包括数据和MAC封装)的字节数。
no buffer
因为在系统中没有足够的缓存从而丢弃的数据包的个数。可以和ignore的计数来比较。以太网上个广播风暴和串行接口上的传输质量不好通常可能会导致该计数器的增加。
Received ... broadcasts
接口所接受到的广播和多播的数据包的数量。
runts
因为小于介质的最小的包大小而丢弃的数据包的个数。例如,对以太网来说,小于64byte的数据包被认为是一个runt。
giants
因为大于介质的最大的包大小而丢弃的数据包的个数。例如,对以太网来说,大于1518byte的数据包被认为是一个runt。
throttles
接口disable的次数,可能是因为缓存或者处理器过载等因素。
input errors
包括runts, giants, no buffer, CRC, frame, overrun, 和ignored的所有的计数器。其他和输入相关的error包也可以造成input errors计数器的增长。同时,一个数据包可能会包括多个的error。
CRC
接口接受到的循环冗余校验和的数量。在局域网中,通常是因为线路质量或者硬件的传输问题,一个比较高的CRC数目通常是有些工作站发送大量坏的数据包造成的。
frame
接受到的含有CRC错误和非整数的十进制数目的数据包的数量,在局域网中,通常是因为碰撞过多或者以太网设备的故障。
overrun
因为输入的速率超出了接受者硬件的处理能力没有硬件缓存来处理的次数。
ignored
和系统的缓存不同,这个是因为接口的内部缓存而造成的接受到数据包被忽略的数目。
abort
接受时中断的数据包的个数。
Frame超长的输入的数据包。
packets output
系统发出的数据包的个数。
bytes
系统接发出的所有数据包(包括数据和MAC封装)的字节数。
underruns
发送者传输过快导致路由器无法处理的次数。
output errors
接口认为的所有传输数据包的错误的总和,同时,一个数据包可能会包括多个的error。
collisions
因为以太网冲突导致重传的数据包的个数。
inter resets
接口重启的次数。在几秒钟时间内进入队列的数据包都没有传输的情况下可能发生。在串行接口上,可能是因为传输的modem故障没有发送时钟信号或者线缆的问题 。如果系统发现串行上因为有载波信号接口up但是协议是down的情况下,接口会努力周期性的重启自己。当接口回环或者被shut down是接口也可能会重启。
babbles
传输的计时器到。
late collision
传输数据包序文报头后发生的碰撞叫late collisions。通常发生late collision都是因为以太网的线缆过长,超出了它所能传输的距离限制造成的。
deferred
因为载波的问题,芯片延后传输帧。
lost carrier
传输过程中丢失载波的次数。
