研究够深刻的, 英文语句都研究, 这翻译过来的语句能说准吗? 明白大概意思就好。芯片内部自举驱动电路原理清楚就行。 翻转 大概意思就是SW的反灌,
关于谐波的消除问题特来请教!1:With RBOOT short circuited to CBOOT, rise time is very fast. As a result SW node harmonics do not "roll off" until above 150 MHz 。这给说短路的时候,谐波在150M之前不会翻转是什么意思能否请各位大神帮忙指导下?2:A boot resistor of 100 Ω corresponds to approximately 2.7 ns SW node rise, and this 100-Ω boot resistor virtually eliminates SW node overshoot. 加了一个电阻100OHM,上升时间是2.7ns,减小了SW的超调?超调又是什么?能否帮忙指点下?
