T型槽平台用途:主要用来固定工件,是钳工工人用来调试设备,装配设备,维修设备的基础工作平台。 T型槽平台的生产过程为 :做型—铸造—机床**—刮研—检验—包装—发货或入库。 平台在生产的过程中需要经过两次回火**,然后上机床**,最后人工刮研。经过两次回火后平台的精度更加稳定,耐磨性能更好,人工刮研可以使铸铁T型槽平台达到理想的精度。
T型槽平台T型槽平台 材质:高强度铸铁HT200-300工作面硬度为HB170-240,经过两次人工**(人工退火600度-700度和自然时效2-3年)使用该产品 的精度稳定,耐磨性能好。
T型槽平台精度:按国家标准计量检定规程执行,分别为0、1、2、3四个等级。
技术要求①T型槽平台工作面不得有严重影响外观和使用的砂孔、气孔、裂纹、缩松、划痕、碰伤、锈点等缺陷。
②T型槽平台的表面应**型砂且平整,涂漆牢固。
③精度等级为0级-3级的T型槽平台工作面上,直径小于15mm的砂孔允许用相同材料堵塞,其硬度应小于周围材料的硬度。工作面堵塞的砂孔应不多于4个,且砂孔之间的间距应不小于80mm。
④T型槽平台应采用优质细密的灰口铸铁或合金等材料**,其工作面硬度应达到170-220HB。
⑤T型槽平台工作面通常应采用刮削工艺。对采用刮削**的3级T型槽平台工作面,其表面粗糙度Ra的最大允许值为5um。
⑥采用刮削工艺应进行涂色对研检验。对研后显示的接触点面积的比率见表3的规定:或者按25mm×25mm正方形面积的接触点数见表3的规定,且任意25mm×25mm中的接触点数之间应不大于5点。
T-slot plate are mainly used as fitting workpieces. Which is the fadation plate of adjustng, assembling and reparing equipments.
The raw material of the cast iron T-slot is the high -strength cast iron HT200-300 ,whose sur hardness is of HB170-240.After the two manual handing such as 600℃ to 700℃ artificial annealing as well as 2 to 3 years of natural aging, the T-slot has plate perfectly resists abrasion and has stable precision.
Precision accuracy-slot plates shall be classified as Grade 0, Grade 1, Grade 2, and Grade 3.
Technical requirements of T-slot Plate:
1.The working sur, when inspected visually, shall be free from blowholes, sand holes, cracks, slag inclusions scratches, porous patches and other visual flaws.
2.The working sur shall be clean and uniform and the other sides shall be painted well.
3,the plugging of blowholes or porous patches in the working sur whose accuracy is Grade 0- Grade 3 with material of a similar composition is permitted provided that such a repair does not affect stability or accuracy.
4,The raw material of Cast Iron Sur Plate shall be the close-grained cast iron whose hardness is of HB 170~220.
5, the sur plate are usually adopted the scraping technology.
6, the sur plate after scraping technology need coloring method for inspection
