序号 ITEM NO. |
电缆编号 CABLE NO. |
回路电流(A) CURRENT |
起始位置 STARTING POINT |
载流量(A) | 电缆 外径 (mm) |
电 缆 CABLE (RVV,YJV,VVR) | 保护管PROTECTIVE TUBE | 电缆质量 (Kg/M) |
电缆型号 CABLE TYPE |
电缆规格 CABLE SPEC. |
长度(m) LENGTH |
管径(mm) DLAMETER |
长度(m) LENGTH |
普通环境,电缆埋地敷设,周围环境空气温度30℃(二、四、六极电机) | ||||||||||||
1 | 0.55~4KW | 20 | 15.4 | VV22-0.6/1KV | 4X2.5 | DN25 | 0.383 | |||||
2 | 5.5KW | 11.1A | 35 | 17.5 | VV22-0.6/1KV | 4X4 | DN32 | 0.506 | ||||
3 | 7.5KW | 15A | 35 | 17.5 | VV22-0.6/1KV | 4X4 | DN32 | 0.506 | ||||
4 | 11KW | 21.8A | 35 | 17.5 | VV22-0.6/1KV | 4X4 | DN32 | 0.506 | ||||
5 | 15KW | 29.4A | 44 | 18.7 | VV22-0.6/1KV | 4X6 | DN32 | 0.616 | ||||
6 | 18.5KW | 35.5A | 61 | 21.7 | VV22-0.6/1KV | 4X10 | DN40 | 0.853 | ||||
7 | 22KW | 42.2A | 61 | 21.7 | VV22-0.6/1KV | 4X10 | DN40 | 0.853 | ||||
8 | 30KW | 56.9A | 80 | 24.1 | VV22-0.6/1KV | 4X16 | DN50 | 1.143 | ||||
9 | 37KW | 69.8A | 103 | 27.7 | VV22-0.6/1KV | 3X25+1X10 | DN50 | 1.485 | ||||
10 | 45KW | 84A | 127 | 29.7 | VV22-0.6/1KV | 3X35+1X16 | DN50 | 1.835 | ||||
11 | 55KW | 103A | 155 | 32.61 | VV22-0.6/1KV | 3X50+1X25 | DN65 | 2.737 | ||||
12 | 75KW | 139A | 183 | 35.5 | VV22-0.6/1KV | 3X70+1X35 | DN65 | 3.557 | ||||
13 | 90KW | 166A | 221 | 39.8 | VV22-0.6/1KV | 3X95+1X50 | DN65 | 4.682 | ||||
14 | 110KW | 203A | 287 | 46.6 | VV22-0.6/1KV | 3X150+1X70 | DN80 | 5.918 | ||||
15 | 132KW | 242A | 320 | 51.4 | VV22-0.6/1KV | 3X185+1X95 | DN100 | 8.461 | ||||
16 | 160KW | 292A | 374 | 51.4 | YJV22-0.6/1KV | 3X185+1X95 | DN100 | 8.461 | ||||
17 | 185KW | 338A | 216 | 35.5 | YJV22-0.6/1KV | 2-(3X70+1X35) | 2-DN65 | 7.114 | ||||
18 | 200KW | 365A | 259 | 39.8 | YJV22-0.6/1KV | 2-(3X95+1X50) | 2-DN65 | 9.364 | ||||
19 | 220KW | 397A | 293 | 42.7 | YJV22-0.6/1KV | 2-(3X120+1X70) | 2-DN80 | 11.472 | ||||
20 | 250KW | 460A | 331 | 46.6 | YJV22-0.6/1KV | 2-(3X150+1X70) | 2-DN80 | 11.836 | ||||
21 | 280KW | 514A | 374 | 51.4 | YJV22-0.6/1KV | 2-(3X185+1X95) | 2-DN100 | 16.922 | ||||
22 | 315KW | 572A | 374 | 51.4 | YJV22-0.6/1KV | 2-(3X185+1X95) | 2-DN100 | 16.922 |
