蒙圈了! 做了一个项目用到西门子的TP177B的触...
 扬眉吐气
蒙圈了! 做了一个项目用到西门子的TP177B的触摸屏,挂DP总线,在组态和调机的时候,在Hardware里将屏挂到DP总线时下方的属性对话框里有两层小格,我将模块型号拖放进去时显示两层均可安置,但不知另一层作何用?如果在此窗口直接编译保存则无错误,但返回到工程根目录编译保存“Profibus”时则会有以下错误信息(下载后程序能使用),求高手赐教!
“Warning: Caution: in station PressHMI there are additional nodes that also have to be reloaded.”
“Warning: Caution: in station TrimHMI there are additional nodes that also have to be reloaded.”
Error: An error occurred creating or interpreting the system SDB. The action will be aborted.
Result: 2 error(s), 2 warning(s)
